Rollers or Sliders
Rollers or Sliders
I use Rollers
19
28%
I use Sliders
13
19%
Weight 10
6
9%
Weight 11
3
4%
Weight 12
3
4%
Weight 13
19
28%
Weight 14
2
3%
Weight 15
2
3%
> 16
1
1%
Total votes: 68
cocteau2x
Color: Blue
Rollers or Sliders
Post by cocteau2x »
Rollers or Sliders
I am considering changing the weights of my rollers in my PCX
I understand the advantages and disadvantages of higher vs lower weights
I am just wondering what the people here use
Which do you prefer?
And what weight?
and why?
chicaboo
Re: Rollers or Sliders
Post by chicaboo »
I like 11-13g sliders in the stock variator, but they didn't feel right in my Daytona variator.
Then I read that the Daytona variator has Teflon coating like the NCY variator = rollers only.
I've also tried 14g rollers in the Daytona variator, and that's a pretty nice relaxed setup.
If you're on the fence, I don't think you could go wrong with either 13g rollers or sliders.
Caution, I get an extra 10kph top speed on the centre stand with 13g sliders over 11g sliders.
This might be a problem if you have a low geared LED model for the US market...
cocteau2x
Color: Blue
Post by cocteau2x »
I have been riding a 2013 PCX for the last 3 years.
And, have been wanting to play with the rollers for a long time.
I would like to see what lighter rollers and the increased acceleration would feel like.
BUT, since I share this bike with my girlfriend, she has a say in what I do to this bike ..
and she says "DON'T TOUCH ANYTHING" ... LOL
so, I am taking delivery of a brand new 2017 next week.
And, new rollers or sliders will be going in to it after I break the bike in.
I am thinking 13g sounds about right (13g seems to be mentioned frequently)
what is the stock roller weight? ... 15g? 18g?
But, 11g kind of sounds like fun.
Can you tell the difference between rollers and sliders?
Do you have a preference?
zanggerk
Year: 2012
Post by zanggerk »
Stock roller weight is 15g as far as I know. I am still using these rollers but have ordered 12.5 g sliders just a few days ago.
BPT7594
Post by BPT7594 »
Stock pcx150 2017 should be 15.5gr
You might have added which vario kit is used first
Over whelming would be this one with 13g rollers.
The NCY teflon kit & rollers will fit all PCX125/150 2010-2017
Improves low end as well as top end speeds over stock variator.
http://www.corsportusa.com/2010-honda-p ... on-pulley/
http://www.corsportusa.com/2010-honda-p ... rive-face/
http://www.corsportusa.com/2010-honda-p ... ights-13g/
https://www.youtube.com/watch?v=-NRc9g3Dasw
And it gets better as it breaks in :D
https://www.youtube.com/watch?v=qS4vpDdGUsw
cocteau2x
Color: Blue
Post by cocteau2x »
2010+ HONDA PCX 125 NCY ALUMINUM DRIVE FACE
2010+ Honda PCX 125 NCY Variator Set Special Gold Teflon Pulley
2010+ Honda PCX 125 NCY Roller Weights - 13g
I need all 3 of these correct?
This is all pretty inexpensive ..
and do I need a new belt as well?
If I do .. what would you recommend? ..
Thanks for your help .. as usual
BPT7594
Post by BPT7594 »
Use your stock v belt.
cocteau2x wrote:2010+ HONDA PCX 125 NCY ALUMINUM DRIVE FACE
Your bike will have the latest Honda Cogged Belt (easily recognized over the original smooth belt) That kit has been around even before the new belts came out and it works great with both belts.
u33db
Post by u33db »
I have 12.5g rollers coming today/Monday for my 125 so will report back how they are compared to stock 15g.
Malossi 10.5g rollers
Malossi yellow clutch springs
HJC wind screen
grndslm
Post by grndslm »
Soo.... based upon
- the idea that changing out ONLY rollers/sliders is the best thing for improving acceleration [and I have no need for more top end]
- and this video --> https://www.youtube.com/watch?v=yxcQGmT8EJc
I think I'll try the 13g sliders (13g is frequently mentioned for rollers, at least... are sliders more functional in a different weight?) with the stock face. Which is very convenient... as no other face will work very well with the sliders, no?
Bummer is that I like the idea of the NCY and Daytona faces having a Teflon coating. Wonder why the sliders don't work well with the Teflon coating... Hmm...
chicaboo
Post by chicaboo »
grndslm wrote:Soo.... based upon
To avoid confusion, the drive face is the outer fixed pulley, and the variator is the inner pulley that houses the rollers. Then there is the rear driven face...
But yes, I tried sliders on the Teflon coated Daytona, and it was atrocious. However, it worked really well with the 14g rollers it came supplied with.
The mechanical advantage of sliders is they have a lower profile at idle and taller profile at high revs, so they offer a gearing advantage over rollers.
I've not ever noticed the lower gearing off idle, but you can certainly see the difference free-revving the scooter on the stand. +10kph with 13g sliders!
Sliders are so cheap in America, that you can buy a couple of sets and experiment. I've got 11g and 13g sliders, and use a mix of the two for 12g sliders.
Year: 18 300 xmax
After a couple hundred miles, I changed to drpulley sliders 14g - loved them
After a year I changed to the entire NCY variator/drive face with 13g rollers - even better.
grndslm
Post by grndslm »
chicaboo wrote:To avoid confusion, the drive face is the outer fixed pulley, and the variator is the inner pulley that houses the rollers. Then there is the rear driven face...
Jge64 wrote:After a couple hundred miles, I changed to drpulley sliders 14g - loved them
Perhaps you both could answer strictly to acceleration at any range from 0 to 55 mph...
Which would be "quicker" from 0 to 55?? .. 13g sliders with stock face? .. or the whole NCY kit (or equivalent brand)??
chicaboo
Post by chicaboo »
grndslm wrote:Perhaps you both could answer strictly to acceleration at any range from 0 to 55 mph...
If they both have the same weight sliders/rollers, the stock variator/drive face will be quicker because it's lower geared (smaller diameter, steeper pitch on pulley faces).
I've done all this testing on new parts or used with minimal wear, back to back with 2 or 3 tanks of fuel in between to give for the belt to settle into the pulley profiles.
The differences you are talking about are quite minimal, but enough for me to notice on launch and in the mid range before the scooter was close to max revs at max speed.
Sliders alone in combination with an HD clutch really gets you moving, too. But you are using more revs at low speed since the clutch doesn't fully engage until 4000-4500rpm.
Year: 18 300 xmax
The sliders for me were quick off the line
The NCY system was just as quick and added top end
PCX89
Color: White 125cc
Post by PCX89 »
Hello, I'm new here and I would like you to tell me if someone has tried a few dr.pulley 13gr on the 125cc engine, really this weight is the one you have to have? I have seen a video on the internet where the bike on the easel takes 4km / h more.
Forgive but I'm using google translate, I do not get along with languages.
Pcxdemon
Post by Pcxdemon »
PCX89 wrote:Hello, I'm new here and I would like you to tell me if someone has tried a few dr.pulley 13gr on the 125cc engine, really this weight is the one you have to have? I have seen a video on the internet where the bike on the easel takes 4km / h more.
My experience with 125 was 10g sliders or rollers were the best for performance with Honda variato. I use sliders as they last much much longer then the rollers.
PCX89
Color: White 125cc
Post by PCX89 »
Thanks for your reply, I live in Spain in Valencia and I do not usually go a lot for city I go for the road a lot of time, I read that 10gr is little, I believe that of stock 15gr and with slippers of 13gr goes well, I am confused and I do not know that install.
If you have a 125 cc and just want to give your bike quicker acceleration off the line, but do not need greater top end, then drop down to 10 gram rollers OR 10 gram sliders, whichever you can get your hands on. This is a quick and easy swap if you have the tools. A shop can do it in 15 minutes.
