Lubing Throttle Cable
Does anyone know how to lube the throttle cable? Thank you.
Re: Lubing Throttle Cable
You don't.jefflam1124 wrote:Does anyone know how to lube the throttle cable? Thank you.
It doesn't require any lubrication.
If you do lubricate it you will most likely damage it.
gn2 wrote:You don't.jefflam1124 wrote:Does anyone know how to lube the throttle cable? Thank you.
Thanks for the quick reply. It is just that I found the throttle a bit sticky to turn and wondering the cable might need some lubrication to make it smooth again.
Might not be the cable, it could be the twistgrip. Bit of WD40 in the right place might help...?
- relic
- Color: red white
As an old time mechanic told me-if it sticks or squeaks spray wd-40-if that don't fix it-hit it with a hammer, if that don't work probably an electrical problem.
