Best Oil to use
Oldtimer79
Best Oil to use
Post by Oldtimer79 »
Hi Guys: Got PCX 125. Thinking of an oil change come Spring. How about "Mobil 1"?
Oldtimer79
Re: Best Oil to use
Absolutely any 10w30 motor oil will be fine.
Mobil 1 is good quality stuff, use with confidence.
Re: Best Oil to use
I use Mobil 1 full synthetic. Have been using it since after the first oil change, and my bike is running fine.
raito
Color: matte silver
Re: Best Oil to use
Post by raito »
I didn't use Mobil 1 full synthetic. Coincidentally, never used a 10W-30 as well. My bike is running fine too.
Re: Best Oil to use
along the lines of "if it's slippery it'll be fine":
Rural King is having a Xmas sale on tubs of bacon fat.
Just push it in, I guess.
Think of the lovely smells at long stop lights......
Re: Best Oil to use
We had a neighbor a while back who used old cooking oil to run his old diesel Mercedes. He got his oil from Chinese restaurants. Strange smell at stop lights. You could always tell that his car had been there before we drove up.
Re: Best Oil to use
Mel46 wrote:We had a neighbor a while back who used old cooking oil to run his old diesel Mercedes. He got his oil from Chinese restaurants. Strange smell at stop lights. You could always tell that his car had been there before we drove up.
I’m getting hungry just thinking about it.
MikeP
Color: White /red
Re: Best Oil to use
Post by MikeP »
If bacon fat and cooking oil are good lubricants, why does it plug our arteries?
I must be missing something....
Conelite
Color: Blue
Re: Best Oil to use
Post by Conelite »
MikeP wrote:If bacon fat and cooking oil are good lubricants, why does it plug our arteries?
That's because human animals were not meant to run on oil, but on grass. ha ha ha.
I have and always ran all my scooters on Mobile 1. 5w-20 changed every 1k miles like a religion. Im in so cal so its rarely ever over 100 degree's. If I rode in a hotter climate i would run 10w-30.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Re: Best Oil to use
Every 1,000 miles is ridiculously wasteful. Who cares eh?
Other religions are available.
springer1
Year: 2018
Re: Best Oil to use
Post by springer1 »
Conelite wrote:I have and always ran all my scooters on Mobile 1. 5w-20 changed every 1k miles like a religion. Im in so cal so its rarely ever over 100 degree's. If I rode in a hotter climate i would run 10w-30.
Well it's only a quart - so there's no downside & your engine says "thank you".
No way I could find it now, but I do recall reading a study on (aircraft) piston engine oil wear analysis and it found that the best lubrication was actually oil partially thru it's "life cycle". Meaning that - over the studied use period - slightly used oil actually accumulated less additional metal, etc contaminants than new oil did.
I don't remember what they said the reason was or if other studies had the same results.
Conelite
Color: Blue
Re: Best Oil to use
Post by Conelite »
It is kind of a waste if I put a lot of miles on my bike but I put less than 2k miles on my bike a year. ha ha ha
Just gives me peace of mind given my bike constantly lives above 8500-red line every time I ride. CVT tuned for acceleration : )
springer1 wrote: No way I could find it now, but I do recall reading a study on (aircraft) piston engine oil wear analysis and it found that the best lubrication was actually oil partially thru it's "life cycle". Meaning that - over the studied use period - slightly used oil actually accumulated less additional metal, etc contaminants than new oil did.
That's interesting. Maybe similar to how a slightly dirty K&N filter filters air better than a freshly washed and re-oiled filter. (that's hard to read ha ha ha)
2017 PCX 150
Z-Bars
NCY Variator
Re: Best Oil to use
There are some guys on the Burgman forum who swear that dirty oil filters do the best job or straining the bad things out.
One fellow used the example of: "which strains better a biscuit or a pair of nylons?" to prove his point.
Remembering my grandmas big fat biscuits - I had to agree - which was scary.
Oldtimer79
Re: Best Oil to use
Hi Guys:
Thanks for the feedback. One of my maintenance manuals says "don't use automobile oil". However, Mobil 1 is accepted as one of the best. --Oldtimer79
Conelite
Color: Blue
Re: Best Oil to use
Post by Conelite »
Oldtimer79 wrote:Hi Guys:
Common misconception when it comes to scooters/motorcycles is that you need to run Motorcycle oil.. Due to the fact that we do not run wet clutches, there is no need to blow the extra money on dual blend Motorcycle oil..
2017 PCX 150
Z-Bars
NCY Variator
raito
Color: matte silver
Re: Best Oil to use
Post by raito »
Oldtimer79 wrote:One of my maintenance manuals says "don't use automobile oil". However, Mobil 1 is accepted as one of the best. --Oldtimer79
Mobil 1 is a brand. I guess they achieved marketing success. Which vehicle manual says that?
I've been using automobile oil for the past few oil changes on my PCX with no problems. I figured using car oil is better for my PCX engine, than using motorcycle oil JASO MA. I can't find JASO MB oil in my small country. Also, I ride a lot these days, I buy 4-litre bottle and use it up well within 1 year.
Re: Best Oil to use
To me, if it meets the minimum requirements Honda recommends, and it is synthetic, it should be fine. The key is changing it . If you don't change it, your engine is screwed. I have read that synthetic oil can go 7,500 miles between changes, but I stick to the 3,000 mile rule for peace of mind. It is only 1 quart, and if you can't afford $10 for a quarter of oil every few months, you can't afford a scooter.
Re: Best Oil to use
Mel46 wrote:I have read that synthetic oil can go 7,500 miles between changes
Some Triumph motorcycles go 10,000 miles between oil changes.
Re: Best Oil to use
10,000 miles?! I won't even go that long in our car! Isn’t that pushing the oil to its limit?
Color: 15 Forza
Re: Best Oil to use
Post by 87112 »
Royal Purple Full Syn
:geek:
