This week I take delivery of my first scooter (motorcycle for that matter) - a 2012 PCX 150 with less than 3000km.
One of the things I noticed on the test ride was that it had a significant flat spot between 50-80kph, which I've seen corroborated on dyno graphs.
My initial goals with the bike are to iron out this flat spot and replace the rear shocks since I'm quite big at 6'2" and 118kg (260lbs).
I'm going to start with either a cheap Bigrow exhaust or fancy Burial WGP twin exhaust from Webike and some rollers and contra spring (and maybe a windscreen?).
Most importantly I just want to free up the 1~1.5hp I see people getting on the dyno with an exhaust, and I'm hoping the rollers and spring will alleviate the flat spot.
I've read that if I disconnect the battery, the ECU should accommodate for the new exhaust pretty quickly. I will likely get the rollers and spring installed at a shop.
Since I have very limited riding experience, I'm not sure if I was feeling a headwind or just regular wind resistance above 70kph. Does a tall screen offer much relief?
I'm looking at the 55cm high World Walk screen at Webike. It sits almost as high as the mirros, so I'm guessing it would be inline with my neck or chin so I will be looking over it.
As far as the rollers go, I've read here that someone preferred 13g rollers to 10g. This is surprising, as Takegawa recommend 8.5g, and don't even offer anything over 10g.
Are roller weights affected by rider weight also, or do they just change the characteristic of the power delivery? I'm looking to get the Takegawa contra spring, but the cheapest rollers I can.
I just want faster acceleration to 80kph for now. The bike was pretty tired over 90kph, and only got to 95kph before I had to back off. It might do 100kph with a tailwind?
Is it recommended to get a HP variator and belt with only an exhaust? I've read that the profile of the vartiator can affect top speed, but I'm not sure this matters with only an exhaust?
Sometime down the track I may go all out with a Takegawa or Yuminashi BBK, cam, manifold, TB, injector and FIcon. But for now I just want the best bang for my buck to get me started.
For the rear shocks, everyone seems to like YSS. Bikerzbits have the YSS G-Euro and Z series shocks in XXL to suit my weight, all for a decent price.
The G-Euros are about $75 more expensive than the Zs. Do the reservoirs on the Gs offer anything worthwhile for the added expense for regular riding on smoother roads?
This is all I pretty much had in mind for my initial mods. For me, stage 2 might include upgraded valve springs and some sort of FIcon to raise my rev limit and increase top speed.
If you guys are happy to share your thoughts and opinions on the above I'd appreciate the feedback.
Cheers, Gav.
