YSS G Shock Arrived - Could Use A Little Help
fun2scoot
Post by fun2scoot »
The YSS G Shocks from BikerBitz arrived. YES! I did not pay for speedier shipping but it only took 6 weeks from Thailand.
First of all, thanks to Dave for great how-to-install thread!. I hope it's that easy on the 2015!
One question though please; The only directions, on the box rear, say to use a 10mm bushing for the PCX (though it does not say what year) and that the bushings would be in the box. But I checked carefully, twice, and there are none.
Does anyone know if a bushing is needed, and if so are they referring to the top or bottom? I noticed there was a little extra lateral room on the bottom mount when I held the YSS shock next to it.
Re: YSS G Shock Arrived - Could Use A Little Help
I don't know that much about the YSS shocks but I would think that the bushing has already been pressed in if you ordered the shocks specifically for the PCX. I have Takekawa lowering shocks on mine and they came with the bushing already pressed in. Does the box they came in have a dot or check mark or some other identifying mark that shows they are for the pcx?
fun2scoot
Post by fun2scoot »
Well, yes, the box is labeled as for the PCX. Maybe I'm expecting too much, you think?
Bushing is clearly there at the top of the shock
geotreker
Post by geotreker »
I believe the bushing in question is already pressed into the aluminum boss on swing arm.
fun2scoot
Post by fun2scoot »
OK, I must be expecting too much from the maker - over-worrying about the extra play at the bottom.
Thanks all. I'll go ahead and put the shocks in and make a small report.
dasshreddar
Year: forzaruckuspcx
Post by dasshreddar »
you don't want lateral play in the shock mounts... use washers to shim.
those shocks look nice, by chance can you weigh them for me.(pounds or grams)
fun2scoot
Post by fun2scoot »
With concerns now alleviated, I mounted the shocks and, as respondents noted, the bushings are all there. I can be such a worrywart sometimes...
Thanks Mel for your wisdom. You were right.
Report: Outstanding! These YSS shocks have a feature the stock Showa's didn't: The ability to lessen the impact of road imperfections. :lol:
The ride is stiff but that is due to their newness and me being at the bottom of their XL weight range (90-120Kg). They're already sweet but will be even better following adjustment.
BTW, installation did not require the removal of the muffler.
fun2scoot
Post by fun2scoot »
dasshreddar wrote:you don't want lateral play in the shock mounts... use washers to shim.
Dashredder, I apologize but I did not see your post until too late and the shocks were already installed, so weighing them was not an option. However, I used a very accurate scale to weigh the packing materials and subtracted that from the weight listed on the shipping label. This should provide you with an accurate weight for the shocks.
The packing materials alone weighed .616Kg
4.09 - .616 = 3.474KG / 2 = 1.737Kg per shock,
or, 3.829lb per shock
or 3 pounds 13.264 ounces, per shock
Hope this helps
txpcx13
Year: 13&14
Color: Rojox2
Post by txpcx13 »
I hope that you installed these with the gas reservoir on the top?? That is where they should be on your scoot, not upside down like we see most of the time. I saw these in person and turned them down for the opposite style(just my personal preference). Enjoy and let us know what you think compared to OEM stock shocks.
2013 Honda PCX (Red) - NCY 13g rollers, golden variator, drive face, YSS shocks, Givi E450
2014 Honda Forza (Red) - Adige 17g rollers, Kappa K466
txpcx13
Year: 13&14
Color: Rojox2
Post by txpcx13 »
Hope this helps
I sent 2 sets to myself about 3 weeks ago(FROM THAILAND to USA), G series and Hybrid.... I will see which ones I like best.
fun2scoot
Post by fun2scoot »
txpcx13 wrote:I hope that you installed these with the gas reservoir on the top?? That is where they should be on your scoot, not upside down like we see most of the time. I saw these in person and turned them down for the opposite style(just my personal preference). Enjoy and let us know what you think compared to OEM stock shocks.
I held the shocks against the bike and considered both mounting options and decided they looked proper with the reservoir to the rear. It turns out this is what YSS wants also because there is a cut-out notch in each reservoir which precisely fits the luggage box. Of course, I only realized this after reassembly.
txpcx13 wrote:I sent 2 sets to myself about 3 weeks ago(FROM THAILAND to USA), G series and Hybrid.... I will see which ones I like best.
Please let us know; it would be interesting. Photos too if you can.
dasshreddar
Hope this helps
8) thanks, might have to get me some.( the lower mounts are aluminium right?)
