Honda PCX Top Speeds (mph)
This is a compilation of top speeds, posted to here and from the old site. Reply here and I'll update your speed!
This should help people keep track of what mods help speed the most.
Scooters with modded drivetrains
60 - Spongebobnopants (US) - speedometer reading - JCosta variator
62 - emstar - GPS - J Costa Variator, Moriwaki exhaust, Kevlar Belt
67 - TexPCX (US) - speedometer reading - JCosta Variator
67 - turbopcx (US) - speedometer reading - 130cc Hi-power boa kit
69 - MpenaS (Portugal) - GPS - JCosta Variator
74 - Corsport (US) - speedometer reading - JCosta variator, Mugen exhaust, Dobeck Fuel controller, etc
75 - pcxdaemon (Australia) - speedometer reading - Kitaco ECU, Daytona variator, Takegawa exhaust, etc
78 - AZPCX (US) - GPS - Kitaco ECU, JCosta variator, Yoshimura exhaust, 120/80-14 rear tire
US Model, stock drivetrains
60 - ragin' cajun - speedometer reading
60 - DJB1976 - speedometer reading
60 - DaveWilliams2112 - speedometer reading
60 - nemebean - speedometer reading
61 - palebeachbum - speedometer reading
61 - Knoxville - GPS
61.7 - PCXMike - GPS
61.9 - Animator - GPS
62 - Maddiedog - speedometer reading
62 - RichDesmond - speedometer reading
62 - PeteCX - speedometer reading
62 - nofear4095 - GPS
62 - Kapang! - speedometer reading
63 - Ole - GPS
UK Model, stock drivetrains
60 - Nich - speedometer reading
60 / 67 - Scottish - GPS / speedo
60 / 66 - Prixon1114 - GPS / speedo
61 / 67 - teamtd11 - GPS / speedo
61.9 / 65 - TC3 - GPS / speedo
62.5 - rich666 - GPS
62.7 - Wooley - GPS
65 - iDiot - speedometer reading
66 - Steve - speedometer reading
67 - uptowndisco2 - speedometer reading
67 - GN2 - speedometer reading
67 - unwinder - speedometer reading
67 - astaffer - GPS
International Models
73 - SeoulFinn (Finland) - speedometer reading
66.25 - efx (Netherlands) - GPS
trigg123
Re: Honda PCX Top Speeds (mph)
Post by trigg123 »
speedo,66mph
Alibally
Post by Alibally »
Speedo 67mph GPS 61.3mph
EddieC
Post by EddieC »
speedo 62 mph, Radar sign 59mph
No modifications
Teamtd11
Post by Teamtd11 »
Just a update to mine. After the first service and with a new phone i did a top speed test again.
Speedo shows some where between 65 and 66. GPS Shows a max speed reached of 61.51MPH
TC3
Post by TC3 »
After the first service I have not got over 59.8 which is 2 mph less than before the first service was done. I wonder if adjusting valves did this?
Sent using Tapatalk
rich666
Post by rich666 »
I managed to borrow my mates Garmin GPS this morning and went out for a quick run.
Speedo Readings - Garmin Readings
Flat ground - 66mph - 62.5mph
Incline -56mph - 53mph
Downhill - 66mph - 62.5mph
It's worth noting that both on the flat and downhill the limiter kicked in and you could feel the engine being reined in and the revs cutting out for a split second.
But as that's whats the PCX is designed to do I'm perfectly happy :)
it tastes like...Eagle!
Updated. :D
Taz
Post by Taz »
Just had mine up to 110 km/h (69mph). Stock except for Ermax +25 windscreen and smaller mirrors. Before with the stock windscreen I got it up to 95 (59) but didnt like the wind buffeting. But Im used to bikes with windscreens. My bike has done 900 km (560 miles) so just broken in (going slowly) and going in for 1st service soon. Ive added the MPH conversions in brackets using 5/8 as my speedo only shows km/h. The windscreen really reduces drag at high speed and Im 6' 4" and 110kg so no lightweight!
Esdain
Post by Esdain »
Taz wrote:Just had mine up to 110 km/h (69mph). Stock except for Ermax +25 windscreen and smaller mirrors. Before with the stock windscreen I got it up to 95 (59) but didnt like the wind buffeting. But Im used to bikes with windscreens. My bike has done 900 km (560 miles) so just broken in (going slowly) and going in for 1st service soon. Ive added the MPH conversions in brackets using 5/8 as my speedo only shows km/h. The windscreen really reduces drag at high speed and Im 6' 4" and 110kg so no lightweight!
was this the speedo reading or gps?
and if its gps, i wonder whats different about Australian bike, no limiter?
As mine has got older it has got slower, down 5mph indicated.
Now won't indicate more than 62mph before the limiter kicks in.
Mileage is 7500, I suspect the culprit is drive belt/roller wear.
Still does 100mpg though so no point doing anything about it just yet.
Taz
Post by Taz »
no it was the speedo, wasnt planning on a speed test. Just glanced down. Wont say what the speed limit there was....
Fiah
Post by Fiah »
gn2 wrote:As mine has got older it has got slower, down 5mph indicated.
Same here, but I think it has had a bit of an impact on my mpg because I often ride at an indicated ~55 mph.
I ride at a steady 55mph indicated for roughly 50 miles out of 54 every day and still get 100(ish) mpg.
edscoot
Post by edscoot »
Took mine in for its 7500 mile service today and got a brand new pcx to use while mine was being done. The new one only had 130 miles on the clock so not run in, but it couldn't get to it's rev limiter :? I only tried to get up to max speed once, not wanting to hurt the engine, but it really struggled to get up to 60mph. I've got a tall screen on mine and I'm sure this must have a positive effect on performance and mpg.
I'll have to start checking my mpg again. I don't know how much roller weights and drive belts cost but petrol is going to be £1.45 a litre before too long so the maths might begin to favour replacements, as the scoots milage increases.
edscoot wrote:I don't know how much roller weights and drive belts cost but petrol is going to be £1.45 a litre before too long so the maths might begin to favour replacements, as the scoots milage increases.
Service schedule calls for replacement of the drivebelt at 15,000 miles.
Given the cost of it, you don't want to be replacing it before then.
http://www.hondascooterspares.co.uk/spa ... 3E56&uid=0
Fiah
Post by Fiah »
gn2 wrote:I ride at a steady 55mph indicated for roughly 50 miles out of 54 every day and still get 100(ish) mpg.
My commute is very similar, with a bit more driving in town. I get about 100 Imp. MPG as well.
Pcxdemon
Post by Pcxdemon »
127 km/h max with 120 km/h easily achievable anytime..getting 2.7l/100km and im not riding to save fuel..
Pcxdemon wrote:127 km/h max with 120 km/h easily achievable anytime..getting 2.7l/100km and im not riding to save fuel..
What modifications have you done?
Bumping this. :)
